IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5484 Views
  • 14 replies
Call Manager 4.1(3)I am using IPMA in proxy mode. Can a manager, that has a call on hold on his phone, pickup that call from the assistant's phone? The assistant can see the call on hold via the IPMA Assistant Console. ThanksTrae
cairns-a by Level 1
  • 333 Views
  • 2 replies
Hi,This morning, I had outage for all the IPTs. We defined the DHCP pool for IPT VLAN in the core switch. As I checked on the logs, I saw a lot of DHCP address conflict messages. After I clear ip dhcp conflict in the core switch. Everything back t...
sam-lee by Level 1
  • 237 Views
  • 1 replies
I've a call Manager 5.0 with a Voice Gateway connected to an Ericsson Pbx (qsig).Ericsson has the connection with the Pstn.I've this scenario:- when I receive a call from an external wired phone I must edit the calling number adding two zeroes- when ...
hi i have configured IPMA in proxy mode everything is ok and fine except one thing. it is that Divert all does not work, when toggeling Divall on assistant application or on manager's phone it appears with the correspoding arrow to appear in Divall m...
Hi alldoes anyone know the default password for the CiscoCCMUser sql account?Is it true, that the sql accounts CiscoCCMReader and CiscoCCMCDR are deleted ifI update the callmanager from 3.3 to 4.2(3)? I just can't find the the usersafter the upgrade....
telefonie by Level 5
  • 222 Views
  • 1 replies
Hi,I have a customer who would like the CallManager 4.2 / IPCC 4.0(5) system to not answer incoming calls immediateley but after three rings (3 times call progress tone which the calling party hears).Anyone has an idea how to do this?Many thanks for ...
r.coppens by Level 1
  • 297 Views
  • 2 replies
