IP Telephony and Phones
Labels
Experts, I use 9999 for dialing into Greeting Administrator. I set that up long time ago. In that I have included:790 holiday greetings791 key voice mails793 main message When I try 793 I hear the message: you are not listed as the owner of this call...
I'm trying to get a 8832 to use wireless network. In CUCM, the device explicity has WiFi as "Enabled" but on the 8832, all the Wi-Fi client setup options are stubbornly greyed out. Even the old school "**#" method doesn't unlock the menus. According ...
Hello, dear support community.   We are facing some problems with 8821 from time to time: it - periodically loses connectivity with its wifi AP being within the range - might freeze while transferring a call - constantly requires IP from DHCP serve...
This will hopefully be a quick one to answer as I assume it either is not possible, or I have missed something obovious. Is it possible to have multiple matches in a call flow? i.e. a call matches a translation pattern, then (the translated number) m...
Steve_etc by Level 1
  • 976 Views
  • 3 replies
