IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6085 Views
  • 14 replies
Is there any way to remove the requirement to press # to dial a party's extension followed by the # sign when using Auto Attendent's Dial by Extension?We want to be able to have the user just dial the extension. I thought about changing the script to...
I have a customer which has 2 sites. Site A has all the CCM, Unity Connection & IPCCX servers with no users nor IP Phones, while Site B has all the users, phones and the two 3825 Voice Gateways. Site A & Site B are linked by WAN only. I have setup 2 ...
Hunt.Lee by Level 1
  • 270 Views
  • 2 replies
Resolved! Reg: DSPs
Hi Guys,How do you find out what kind of PVDM is installed on the voice gateway. For example whether it is pvdm2-16 or pvdm2-48. And also is it possible to see how many DSP's are on the router.Tks
I was asked to look for a way to get Report on our E1 links of our H323 Gateways. So i tried using RTMT (Call Activities Reports Archive) and got the attached diagram as Result. Can anyone tell me how this Diagramm can tell me if our 4 E1 (120 Channe...
Ok for some reason I am having a problem with this. Which settings in Call Manager forwards digits to the pstn? Is it "external phone number mask" on the phone?Also, I know this call is going through my gateway, which setting on my dial-peer will for...
dvanzee by Level 2
  • 327 Views
  • 1 replies
Hi:I have a Cisco 7961-G-GE IP Phone that will not regsiter with Call Manager. It shows that it is registered in Call Manager but does not show any Directory number on the Phone display. I did the factory defaults and still no luck. It has the latest...
agnel by Level 1
  • 879 Views
  • 4 replies
I am setting up phones at a customer?s DR location. They would like for the phones at this location (DR) and their other branches to be able to dial extension-to-extension over the WAN still after they go into SRST mode. So, it is assumed the CM serv...
is there anyway to set a password policy for the phone users, such that when they web access there phone for 1st time, they are forced to change password to a longer length than the default of 5? similar to what can be done with unity subscribers.cal...
rvincent by Level 1
  • 418 Views
  • 4 replies
