Resolved! ISR4331-V/K9 users license
HiI have ISR4331-V/K9. I want know how many users can I active in CME vs CUCM Thank you
Hello everybody I have a problem with a SIP trunk and external calls forward to external. let me explain : here is my configuration : CUCM ----- SIP Trunk to -----> CUBE ----- SIP Trunk to -----> ITSP inbound, outbound call work perfectly in...
I need some help, I need to configure a 2951 to handle the SIP trunk for connectivity to the PSTN, then the inbound call needs to leave out the Cisco 2951 via 1 of 4 FXS ports. I have a pretty good handle on the SIP trunk, I have never configured FX...
Hi All, I am trying to understand the voice translation rules and have got confused with complex usage of it. Below are some patterns : /.*\(...\)$/ /8\1/ ---- My understanding - This means any number being dialed is prefixed by 8 followed by the 3...
Hi,We have a 3945 with Version 15.5(3)M5 with CUCM 10.5 We have a new ITSP provider that require authentication. We have configured the authetication in dial-peer level:dial-peer voice 20 voip description ** Outbound SIP-ISP ** .... authentication ...
I have setup a SIP trunk for our office in Germany. Deutsche Telekom insisted we had to move off ISDN, as they are replacing it with SIP. I used the following guide as help me https://www.cisco.com/c/dam/en/us/solutions/collateral/enterprise/interope...
HiI have a VG204 with IOS: vg20xxm-ipvoice-mz.159-3.M.binBut I can't register the VG204 to my CUCM 11.5 VG Config:stcapp ccm-group 1stcapp!stcapp feature access-code!stcapp feature speed-dial!voice service voipno supplementary-service sip handle-repl...
Hi Everybody, Here is the environmentCUCM 10.5 - PUB 10.10.242.51CUCM 10.5 - SUB 10.10.242.52I am going to re-host the CUCM pub, the following is my procedure1. DRS backup CUCM PUB (on OLD UCS) 2. DRS restore CUCM PUB (on NEW UCS) (on a separated net...
Unity Version 11.5 We have an Auto Attendant set up for the main phone number of our business. Callers are able to dial the extension of a party from this menu if they know it, but those calls go directly to voicemail rather than ringing the line. Ho...
Our setup was done by a vendor and worked well. All of the sudden 911 calling stopped working. We get an immediate busy signal. I talked with our telco provider and they tell me they can't replicate it so it must be our equipment. I am looking for tr...
When i got my 2901 voice router i deleted all the files off it that i thought could have to older configurations from the previous owner but that included all the ringtones and the two xml files that are apparently needed RingList.xml and DESTINCTIVE...
Hi all,Hope someone out there knows of a product that can help.Looking to control some devices VIA dry contacts. Looking for a device that can accept SIP calls and has a dry contact relay.Preferably has more than 1 relay so i can dial *1 to control d...
Hello, I'm having some issues with the "unlocated phones" report from CER v11.5.4.50000-6. I have many phones in the report with the status of "Switchport Configuration" under the "Why this ERL is used?" column. Problem is that all the phones lis...
Hi,There are a couple of sites that I'm trying to get working without MTP, and I'm having some problems getting consistent results where the calls need to use G729. Two things seem to be irreconcilable ..(1) Outbound call via CUBE, of CUCM presents...
in Unity 12.5 CLI, I run a license smart reservation return and get the following. Error occured while processing request :com.retrogui.dualrpc.common.CallException: <remote_exception><sessionid>5440245</sessionid><class>java.lang.NullPointerExcepti...
| Subject | Author | Posted |
| 11-16-2025 10:18 PM | ||
| 10-15-2025 09:15 AM | ||
| 09-26-2025 02:09 AM | ||
| 09-24-2025 11:48 AM | ||
| 09-19-2025 06:42 AM |
| User | Count |
| 4 | |
| 1 | |
| 1 | |
| 1 | |
| 1 |
