IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6094 Views
  • 14 replies
hello...anyone would explain how many telephone call supported when pvdm a has 2 DSP? what relation call with channnel? because i saw router has one pvdm but only say it support 32 channel. does it mean 32 call concurrent?
jemekeren by Level 1
  • 370 Views
  • 4 replies
hi guys...what possible trunk can be connected between pbx and cisco router in short cable (5 meter)? is it E1/T1... ops.. by the way do we only need plain e1/t1 without kind of signal such pri? please help... beside that how dialpeer would map to th...
  • 288 Views
  • 3 replies
We currently have CM 4.13 with Unity 4.05. Unforturnatly, after we made numbering plan with 9XXXX many people calling 911 with mistakes. Now, we like to change/modify CallManager and Unity configuration so number will use 6XXXX instead of 9XXXX. We a...
u.heepark by Level 1
  • 240 Views
  • 1 replies
