International Call report in CM
Is there a way to run an International call report in Call Manager? To find out which International calls have been made and by whom. Any info would be great.
We have a H323 gateway with different bearers on each interface. Our CILE cannot establish which interface was used for a call so we are unable to apply correct tariff. Is it possible to distinguish interface used?
We have two PRI connections between router and pbx running wth isdn switch-type primary qsig, outbound calls from the pbx work fine and all b channels work okay. For inbound calls we have the following situation PRI 1/0 - Channels 17 - 31 not working...
my voice gateway has many IP address, when my mgcp gateway registers on CCM, which ip address it uses for register? the higher ip add ? can I use a loopback ip add ?
Hi GuysI am having a very strange problem that I am hoping someone can help me with:I have installed CCM 4.1(3) on a laptop. I have performed a non-mcs installation hundreds of times before without any issues. During this installation, there were no ...
Anyone know of a way to verify whether an fxo port on a remote device has a live line connected to it or not? We have routers in remote locations that we believe the CO loop lines are not functioning or connected to the wrong ports. Wanting to know...
Hi,I have couple of 7936's that keep rebooting in one of our offices.I know they both work because of i move them to another office they work fine.I have adjusted speed/duplex , removed the voice vlan and also updated to the latest code 3.3.12.Any id...
I,ve got an 2821 gw with dsp an fxo ports, when the router recieves a call on the fxo port the call is forwarded to the ip telephone and fails, busy tone is heard form the telephone that is calling.The CSS, partitions and the mgcp is configured right...
I have a CCM setup, and have the strip g729 silence suppression/VAD Annex B capability from codec set to TRUE under CCM service parameters, but calls across WAN are showing up as g729br8 that come in from PRI on MGCP gateway. There is a 6608 being us...
I?m having problems with a CCM 4.1(3) cluster that consists of one publisher and one subscriber. If a new phone registers to the publisher, no one can call the phones extension, even though everything is setup correctly. What would cause this?Thanks,...
I am using a 2811 router with CCME on it and have a hwic ap. I am trying to get a 7920 to work. All the display says is connecting to callmanager 0. The phone picks up a dhcp address,tftp address and can ping the phone address. I have attached config...
i need some help in setting up transfer recall on the ccm 4.1...as in when we transfer a call to somebody and it's not answered after a 3-4 rings, it should be transferred back to the person who transferred it.
Hello folks!I try to use it but it doesnt work, in fact I do the follow steps and neither work:For Windows 2000/XP: From Control Panel execute the "Add/Remove Hardware" utility. Select "Add/Troubleshoot" when the prompt "Choose a Hardware Task" is di...
Has anyone run into an issue getting a 7936 conference phone to register to call manager?CM version = 4.1 3 sr2
Hello,I'm new with Cisco.We are completly rebuilding our sites and we look to use VOIP.We have 3 sites :- 1 in Belgium : approx 50 users- 2 in Frans : 5 users. (and all call from Belgium to anywhere in Frans transit via one of them)Between these site...
Subject | Author | Posted |
01-25-2023 05:07 AM | ||
01-24-2023 11:30 AM | ||
01-19-2023 08:07 AM | ||
01-16-2023 05:26 PM | ||
01-16-2023 10:22 AM |
User | Count |
8 | |
7 | |
4 | |
4 | |
1 |
