IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5886 Views
  • 14 replies
this may seem a silly question, however i'm still going to ask.i have configured CME (3.3) and have an E1 PRI voice circuit to the PSTN however my voice vlan (3) is fine, however data access (i.e. services and browser acccess) would be gained throug...
Hi,I have kind of a newbie question and am sorry for posting such queries but I can't find an explanation anywhere on the net. I am wondering what you understand under the term "toll bypass" and how you associate it with VoIP. I am currently studying...
Hello everyone,I have another strange issue with an IP phone that doesn't want to ring.There are 4 analog lines plugged into an FXO card in the router, and all are configured the same. The lines are PLARed to the phones - and all but one are working....
Hi,Cisco7941G with CCM5.0(4a), we tried to use the Plantronics 26716-01 cable which it says it does not require any amplifier and can be directly connected to the phone as per following:http://www.headsetsdirect.com/accessories/26716-01.htmlBut the h...
jjia by Level 2
  • 661 Views
  • 1 replies
I have a production unity, vm only, that I will be migrating to a new server platform. On the new server, I have Unity installed up to the point of the telephony integration. On the DiRT procedure, I see that Unity must be completely installed befo...
Hi All,I have a CCM 4.1 configured at 2 differents site Cluster1 & Cluster2 linked by a trunk.Calls are flowing successfully over the trunk.I have configure the directory and can access them on each cluster.My problem is that i cannot access director...
Hi,I am having problems with an FXO card in the UK (BT is the telco). Could anyone please post a working Voice-port config for a single analogue BT line connected to an FXO port?I have tried numerous settings and can't get it to work. When I make an ...
