IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6330 Views
  • 14 replies
Hi ALL!I have CCM - version 4.1(3)sr2. Voice gateway -MGCP 2811 have connection to PBX Ericsson MD-110 via QSIG. This gateway included in Route List.I have route pattern on CCM which must do called number transformation.When I am doing test call I se...
v_milenko by Level 1
  • 479 Views
  • 1 replies
Hi there,some months ago, the company i work for installed windows 03 SP1 on an exchange server that communicates with the unity, and now unity cant communicate with it anymore. After a thorough search on cisco's website, i came across a couple of wo...
achalante by Level 1
  • 315 Views
  • 1 replies
HelloI have just set up a test environment with a CCM 5.1 and 3 IP phones (1x7960 + 2x7970).Got everything working just fine, but there is one thing I can't seem to get to work. All of the 3 phones have attached the 7914 Expansion Module. When user 1...
rasmusan1 by Level 1
  • 286 Views
  • 1 replies
I have 2 CCM's with ICT(no srst, no mgcp) b/w them, with 2 ip phones connected to Each CCM. I make a call from one ip phone - other ip phone and one end of the CCM crashes, will the Voice call continue..p:s - No Mgcp, No H323, it is a ICT b/w CCM
Hi, I'm facing a new problem since using 8.X versions for a 7941.When I enable DND (NoMlsta in spanish), there is no way to disable it. Using the button doesn't works, nor restarting the phone, only rebooting the ccme!Is it a known problem, or a new ...
Resolved! Unity 4.0(5) DST
I have unity 4.0(5) running on win 2000 server. I have applied the windows patches and the server has the correct time. Unity has incorrect time when checking voicemail. I am missing a file that is outlined in step 2 for the patch.Can anyone help?...
jnichols by Level 1
  • 608 Views
  • 6 replies
HiStarted working on a new network recently and, through hitting "?" on my phone noticed the Codec was "lin 17k".Not come across this one before so searched CCO -Nothing !Has anyone else seen/used this ?The qaulity is quite poor so as this was an on...
knowlerp by Level 1
  • 482 Views
  • 3 replies
