IP Telephony and Phones
Labels
I have 2 sites connected through ADSL bridges. In the main site I have CCME running on a Cisco 2811 and the child site CCME on a 2801. I am using dial-peer to pass calls between sites. I was wondering whether it is possible to use functions such a...
aseychell by Level 1
  • 299 Views
  • 2 replies
HiWe have call center with Cisco IP phones connected to the PC. Some of the PCs are half duplex and cause problem on network. Is there way to enable lamp on certain phones via CCM so that technican can go to the PCs attached to the Phones and change ...
Hi,Currently we use Whatsup Pro to monitor our network. Can you make WMI call to CCM and Unity? If so what kid of information can you get and how?Also what type of applications do you use to monitor your CCM.ThanksRaj
rshoker99 by Level 1
  • 327 Views
  • 2 replies
Hi,I've just integrated a CCM Cluster running 4.1.3 sr4b onto an AD 2003 environment. Everything is working fine apart from MLA which returns the following error when attempting to access the user groups or assign privs to user groups:"failed to get...
