IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5879 Views
  • 14 replies
It doesn't matter if the phone is on PoE or direct power, the phone keeps cycling the power. It get to the first light of the boot up sequence, then starts over again. Has anyone else experienced a phone like this?
jfaaborg by Level 1
  • 624 Views
  • 3 replies
Resolved! CER PSAP number
I have a overlapping dial plan problem. I have a CTI route point of 913XXXXXXXXXX and a PSAP of 913XXXXXXXXXX. This causes a problem with a route pattern. I would like to change this to 999XXXXXXXXXX at both the CTI route point and the PSAP. Plea...
Resolved! Configuring 7920
Just a quick question...Is there a way to configure this phone without using a USB cable and the Configuration Utility?I've got them on order now but was hoping there was a way to get this 7920 working before they get here.Thanks for your help.
Hi,In my CCM 4.1(3)when I try to run any report using the CAR tool, the reports are blank... all the values show 0.... however I have checked the SQL database, there I could find entries available in the CDR tables...What would be problem ?Regards
rv_viji by Level 1
  • 762 Views
  • 1 replies
Hi,I have 2811 series router with FXO ports. We use 7940 and 7960 phones. Gateway is setup in Call Manager as H323. When calls come in, it takes 3 PSTN rings before the router answers the call (as seen by ccapi debugs). The only config I have on the...
