Folks, How can I program the callmanager so that it automatically adds a 9 or a 91 to incoming calls so that users can go to diretories option and hit dial without using the edit button?Thanks
Will CallManager 4.1x run on a Microsoft Windows 2003 Server platform? Or is it confined to Windows 2000 Server?
I have a production 2851 gateway with call manager 4.2.3. I have added a vic2-2fxs card to one of the slots, 0/2/0, and have done the "update / reset gateway" through ccm, and the "no mgcp / mgcp" commands on the router. However, the card does not ...
If I want to run VoIP on my 2610 routers (running XM image c2600-j1s3-mz.123-16.bin) do you know whether I can setup the FXO voice card and make this work if I have the ENTERPRISE BASIC image ?Someone told me that I should run the IP Plus IOS. Howeve...
Hello all,This is driving me nuts! System is a 3825, 12.4(9)T1, CME 4.0. My innternational dial-peer is as follows:dial-peer voice 9011 pots description International dialing destination-pattern 9011T port 0/0/0:1 prefix 011As soon as I hit the "0"...
I have Unity 4.1 Exchange 2003. The problem that I'm having is that MWI lights are not coming on. I receive a voice mail in my email but the phones do not light. If I do a refresh status the phone will then receive the proper MWI action. The way ...
Hi,I am running CCM 4.1.3 SR2. 7941G phones which are registered are continuously rebooting and going on re-registering. Any workouts for this issue.Thanks in advance.
In a call manager system that does not use moh when you put a caller on hold you get a tone. We had a complaint that the tone is too loud. We would like to know which wave file is the "on hold tone".
Folks, I have ccm4.1(3) is it possible to foward a call to my cell phone if i am not at my desk without hitting the call forward all button, I am looking for something like follow me feature in which if my desk phone does not answer, the phon...
hi, i would like to graph the number of active calls in a gateway in OpenView, as i can do with traffic or processing, does anybody know any MIB that can be used for this?
How do you configure a basic IVR on a 2801 platform?
During restore of Unity 4.2, I recieve the following error.... Failed to gain exclusive access to SQL to perform the restore. In services I have terminated the services ?MSSQLSERVER? and ?SQLSERVERAGENTS? and still recieve this error. Any ideas??
here is my system, multiple-sites with Centralized-CM and Unity. remote site talk to each other by G.729. for Unity, it is a integrated Message system, Users access VM by IMAP client, but my customer doesnt buy any viewmail . here are the questions r...
is there a way to use the upload step to upload a new prompt to another ipcc server? I have another set of ipcc servers that use the same prompt fileThanks
Hiwhen a 2nd call comes to the ip phone(which has already a call), calling person hear ringing tone instead of busy tone. This only happens internal calls.If i call from outside i mean PSTN , it is ok, it gives busy tone for 2nd calls.ccm 4.1.3thkns
Subject | Author | Posted |
03-14-2025 01:29 AM | ||
03-12-2025 07:27 AM | ||
03-06-2025 12:59 PM | ||
03-04-2025 09:05 AM | ||
03-03-2025 01:47 PM |
User | Count |
6 | |
4 | |
2 | |
1 | |
1 |
