Hiwhen a 2nd call comes to the ip phone(which has already a call), calling person hear ringing tone instead of busy tone. This only happens internal calls.If i call from outside i mean PSTN , it is ok, it gives busy tone for 2nd calls.ccm 4.1.3thkns
i have a 7940 that will not register with ccm. this is a new office install so there are no other phones that work. the phone is stuck on "configuring cm list". the phone has worked in another office on a different subnet. i noticed during the boot p...
Hi All;I bought CM 5.0 and I need to obtain license file. First I need to have PAK. when I bought CM, nothing came with CM. How can I get PAK first? and where can I find "license registration web tool" in cisco.com to have license file? thanks for yo...
is there a way to change the 100 record limit for the CDR Extension Report? If it can't be changed how do I get a report with all records for that extension?
within the same cluster is it possible to have multiple attendant console setups. For example you have attendant console setup for each branch office in different time zones and different main line office numbers. Also is there a license limit on the...
How do folks monitor the WAN QoS to find out how much bandwidth VoIP is using so as not to exceed the recommend 33% or to find out specifically the percentage of bw used?
On IP Communicator (version 2.0.2)is there a file where are the user's settings are located and could be manipulated such as an INI file?Thanks!
I'm trying to use the bulk import tool to to import some users and i get an error "couldn't create user object" there is also info that the DC service isn't running. but i looked and that service is running.Thanks for your help.
We ve made an int?gration of our callmanagers with the domain and our policies doesn t allow to have a user AC with password 12345. We can t change the global policies, we don t have the control on it.Any idea how can i use the attendant console?Rega...
how we can integrate the CCM Version 5.0 (sip supported ccm ) with the sip supported microsoft office communicatior 5.0. kindly reply back with your valid suggestions and documents.regardssunny
Hi,I need to control a phone not associated to a CCM in .NET, but I do not know how could I do that. A solution would be to create an ITPhone object, but for it I need a line registered and, in my case, there are no possible line to control.Thanks.
Hi, I have two call manager clusters - CCM Cluster1 and CCM Cluster2 as shown in the diagram. Non-gatekeeper controlled ICT is configured between the two CCM.The configuration of both CCM is as shown in the diagram.I would like to understand the RTP ...
Hi all!Is there any information about license unit cost of IP phones except that one? http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_qanda_item0900aecd805009fc.shtmlI can not find info about "cost" of 7206G phone in CallManager 5.0.Tha...
Hi experts,i recwntly joined to a company as ip telephony and network admin.The person who taken care upto this time wants to handover the things to me.I am very new to such a situation.So any one could suggest me what the documents and configuratio...
in normal cisco ip phone we can make conference calls while dialling out.but how we can have conference while dialing in.is there any third party software support for the same to dail in conference call.regardssunny
Subject | Author | Posted |
04-15-2025 02:12 PM | ||
04-15-2025 10:57 AM | ||
04-15-2025 03:40 AM | ||
04-14-2025 01:50 PM | ||
04-14-2025 08:21 AM |
User | Count |
2 | |
2 | |
2 | |
1 | |
1 |
