IP Telephony and Phones
Labels
Dear all, I always encounter problems when making long distance calls - the phone exits automatically after 3 seconds if I do not continue to press the numbers.    Is there any way the phone's default waiting time can be lengthened  ?      It is not ...
I need to provide a coverage in case CTI RP gets unregistered. Coverage needs to be different for each location. I can add the same DN in multiple partitions to the same CTI RP. Or I can create multiple CTI RP with a single DN. Is there a preference ...
I have two ISR 4451s that are being used as CUBEs.  We are having a problem with box-to-box redundancy.  The two Cubes are using portchannels to provide fail over.    One port of the port channel goes to a 3850 switch (switchA) the other port goes to...
Hi all, Recently we have purchased 8831 conference phone. But in our CUCM default ad hoc conference limit is 4 . If i change the ad hoc range to 6 it will effect for all the connected phones. Now, my request is we need to configure maximum or 6 confe...
