IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5903 Views
  • 14 replies
Hi,   I have two AVAYA 9608G registered with CUCM. But issue is that both are unable to call each other. Even I am unable to make a call from cisco phone to avaya phone. need help to solve the issue.   I have to enable AUTO qos for AVAYA phone on cis...
Hi,If I have a two pstn gateway ,What is the best way of creating route group ?Adding both pstn gateway into a route group or create different route group for each gateway .In my case I have a two pstn gateway and tsip trunk .Requirement is if sip fa...
Hello,I would like to setup a Bluetooth headset so that the pickup button and volume buttons can pickup calls and adjust volume when connected to a Windows 10 machine using jabber.This headset can work successfully with Cisco IP Phones 8851.The sound...
mrjelly by Level 1
  • 689 Views
  • 0 replies
