IP Telephony and Phones
watch here Journey banner_2
Labels
Hi All, Phone load: sip88xx.12-1-1-12 Environment: Phone 8841 (Boss) and Phone 8811 (Assistant) Scenario:Phone 8811 having 2 lines on her phone (which is line 1 belongs to 8811 and line 2 belongs to 8841)When 8841 incoming call, boss pick up his call...
waiwai by Level 1
  • 711 Views
  • 0 replies
Hello All, I'm working on an 8.6 CUCM cluster where the publisher is hosed and I cannot run BAT.   Backup and restore from subscriber is not an option (don't ask).   I need to be able export all phone details from SQL/CLI so I can import into a new C...
Resolved! FAC Code
FAC code is displayed while typed on the phone on CM 8 is the parameter you can tick to hide? I've checked the configuration its correct and the parametres on service parameter are still set to the default
9971 cisco ip phone is dialing numbers randomly internal and external from the placed calls list. No spped dials or BLF is configured on the phone. Its dialing even when office is closed I mean there is nobody even prssing Edge of phone screen frame ...
I have an issue On cme version 9.1 B-acd Music on hold is working normally with the default                        " en_bacd_music_on_hold "  when i change the MOH to another one with the same file name and the same attributes it doesn't work
AMeselhy by Level 1
  • 1506 Views
  • 4 replies
Top Solution Authors
