IP Telephony and Phones
watch here Journey banner_2
Labels
Resolved! CUBE placement
I'm setting up Home Lab for CUCM and a couple of IP Phones. I've got CUCM, CUE, IP Phones, and CSR1000v set up virtually on ESXi 6.7. I want to be able to send and receive calls to the PSTN now via a SIP provider. Everywhere I've read, it states I ne...
vsdhillon by Level 1
  • 1666 Views
  • 3 replies
Resolved! ISR4321-V/K9
Hello, I want to buy a bundle ISR4321-V/K9 but i don't know what is included. because I want to install 2 X FL-CME-SRST-25=  and 2 X NIM-4FXO and one PVDM4-32I need to activate the SRST service for 50 phones and I'll need transcoding on  that router....
Do anyone knows what is the purpose of configuring backhaul on MGCP.. I understand when MGCP-PRI backhaul interface is configured , q921 will be terminated on the MGCP gateway and q931 signal will be sent to CCM . But what i don't get is whats the ...
pravkuma by Level 1
  • 10143 Views
  • 9 replies
I have attached a screenshot of Cisco RTMT that shows the calls.  We receive calls that are labelled as "911", however, there is no answer.  More than likely it's a spoofed call, however, has anyone else run into this and if so, how did you remedy th...
plavin001 by Level 1
  • 706 Views
  • 2 replies
Hi!   I'm upgrading a UC environment from 11.0 to 11.5. One of the pre-upgrade tasks is to ensure the subnet mask is in the recommended format for /24.   "If you are using a 24-bit IP subnet mask, ensure that you use the following format:255.255.255....
Knowlesy14 by Level 1
  • 1859 Views
  • 10 replies
I have set up a SIP trunk from my  3rd party PBX to my IOS 12 voice gateway which in turn forwards calls to CUCM. Calls from phones registered on CUCM are working fine, however calls from PBX to CUCM via the router do not go through. The phone keeps ...
DavidW by Level 1
  • 3004 Views
  • 4 replies
