IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 1222 Views
  • 6 replies
Hello Everyone,   I have a problem were i have set up a MGCP Gateway With a FXO port for a customer, i have set it up so that when a call gets in, it gets delivered to an AA in unity connection, now the call gets connected fine but the issue i have i...
i see this problem happen frequently.  Does anyone recommend any steps to take to attempt to remedy this issue before escelating to ISP?  is there anything I can do to dig deeper or resolve the issue myself?     Router1#sh controllers t1T1 0/1/0 is u...
Amafsha1 by Explorer
  • 389 Views
  • 11 replies
Hi all I need to block a numberfrom being dialled from our cucm to the outside, for example the number is 112233445566 How would I do this on the cucm and h323 pstn gateway? we use 9@ on cucm for outside calls on the gateway we have some translation ...
Are there any issues with upgrading my phone load from sip88xx.10-3-1-20 directly to sip88xx.12-1-1SR1-4? My current version of CM is 10.5.2.13900-12.   I tried to look for the matrix for the new phone load and couldn't find my answer. Thanks for you...
DD4 by Beginner
  • 358 Views
  • 2 replies
Hi, This one has got us into a challenge.  Is there way to get number ( only counts) registered devices ( all types) per devicepool or location from CUCM ? We are trying to monitor periodically the registration stats per location / devicepool. Since ...
Hi everybody, I'm continuing my Asterisk project (with Xivo/Wazo distribution) and I'm deploying several CP8851 (+KEM) and several SPA512G for my Proof of Concept.   Hoewever, I have an annoying problem : BLF function keys don't work. I use SEP File ...
J0hannesR by Beginner
  • 592 Views
  • 1 replies
