Hi,I have the following conditions.Have sip trunk which is connected to remote non cisco pbxAnd route group with two mgcp gateway on premise . I need to achieve the following . If the user calls calls must go through sip trunk . If sip trunk fail...
Hi, Can I install a CP-7841 phone on a UC540W? I actually bought both and the phone is constantly showing "Unprovisioned" on it. Thanks
Hi Folks, I am using cisco its-CISCO.2.0.2.0 tcl script for Auto attendant. I need to know if this supports SIP trunk between Telco and VG. Thank you.
Dear All,I have a few Cisco 8865 and DX650 connected over Cisco Phone VPN. The VPN is terminated on the Cisco IOS router (2900 Series). Now my company changing is DC to another City and will be having a Different Provider or IP address. The VPN setti...
Hi I understand that the phones need to be registered in CUCM as and endpoint under Essentials, but does the VG310 require any CUCM licensing or any other licensing? I have a customer that believes this is so but I am doubtful Thanks
Hi Guys, I have 3 IP phones 7960 and one is registered with router 2811 and two not registered! The one is registered i added load 7960-7940 P00303010200.loads under telephony-services and is OK but the other two is load 7960-7940 P00308000900.loads ...
Hello guys I have a doubt, I need to enter web-based management interface of my phone but I am confusing, this one is the SAFE CARE PORTAL or it is the web you access only with the IP of the Phone (Web Access)?
On of my user raised a complaint saying the persons on the other end of calls sounds muffled for almost all callsHe uses cisco IP phone model 7960 phone and its call manager version is 11.5Kindly help on how to troubleshoot on this issues from scratc...
Need to understand conditions where call setup will bounce to a second FXO port in a Route Group. We had a condition where the primary port in an FXO Route Group for 911 calls was selected, but then hung, never bouncing to the second port. Both ports...
I have an issue with a 8845 that I am not able to select the ABC softkey (grayed out) , I would like to do a sipurl dial, however I don't see the options for CME 12.5 not running CUCM. Any help would be appreciated. 8845 running, load 8845 sip8845_65...
Hi Guys, I have a hunt pilot that has several hunt list members. I want to limit the concurrent call received by the members up to 3 concurrent call, so the 4th caller will be notified that the line is busy (voice recording). I did some digging, so...
Hi all I am having a hard time to make rerouting work properly to an international call. The premise is that we need sometimes to forward calls to an international number we use for Standby. (Everything worked when calling a national mobile phone...
Pulling my hair out. I have a team that wants to play the Standard greeting from a Call Handler, then when Caller Input 1 is selected, they want to play ANOTHER message, and then transfer to an outside # (on-duty cell phone). I get the first 2 parts ...
Hello, I can not retrieve saved voicemail, new voice mails can be retried no problem When attempting to play saved messages I get the error The message is not currently available I have checked that critical services are started, I checked RTM...
we are having an internet office. we need to deploy some phones and routers to that site. what is the possibility to register the phones and routers in internet office.
| Subject | Author | Posted |
| 03-21-2025 01:42 PM | ||
| 03-20-2025 05:12 AM | ||
| 03-19-2025 06:53 AM | ||
| 03-18-2025 05:41 AM | ||
| 03-16-2025 03:42 AM |
| User | Count |
| 5 | |
| 2 | |
| 2 | |
| 1 | |
| 1 |
