IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5875 Views
  • 14 replies
We have configured Cisco 7841 IP Phones and 88XX series IP Phones.   1 We are able to make concall internal numbers IP Phones properly  and call log list numbers. 2 Not able to make concall on external numbers by inputing manual numbers: When we try ...
Resolved! Hunt group
I need to have a phone ring three times when you call and if no answer then go to a broadcast group. Can I do This? There are 8 members on this group. The first time you call a member of this will need to have the same configuration. Thanks
jcconde01 by Level 1
  • 737 Views
  • 3 replies
Hi   I have a few hundred c7945 phones registered. The majority show the load/active IDs as follows: Load ID - SCCP45.9-4-2SR1-1S Active Load ID - SCCP45.9-4-2SR1-1S   I’ve noticed about 10 show the Active Load ID to be different: Load ID - SCCP45.9-...
Chin Jam by Level 1
  • 3469 Views
  • 6 replies
