IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6171 Views
  • 14 replies
Has anyone encountered an issue with the 8845 phones where the background light won't turn off? The phone has not settings to set the background screen time so I assume it will get the phone idle off setting on CUCM. Thanks! CUCM: 9.1.2.12900-118845:...
RbkMan by Level 1
  • 2429 Views
  • 3 replies
Hi,i have a UC520، and it show the below error:"Oct  6 09:47:31.695: %SCHED-2-EDISMSCRIT: Critical/high priority process VTSP may not dismiss. -Process= "VTSP", ipl= 0, pid= 236,  -Traceback= 0x80E728F8 0x8209D2D8 0x80E5ACA0 0x80E8BFD0 0x80E8A9E8 0x8...
Hello,   I've noticed that firmware 11.2.1 (I haven't tested for older versions) violates SIP specifications in an embarrassing way when sending a re-SUBSCRIBE within an existing dialog. More specifically, the phone (a 8851 in this case) doesn't use ...
gedia by Level 1
  • 794 Views
  • 4 replies
Hi Guys, My Customer is having problem with few calls (in alleatory extension or directory number) where the side on company the User don´t hear another side. Question: what logs is more recommended to collect then to analyze this issues?. I collecte...
wilsonsant by Level 6
  • 1794 Views
  • 12 replies
Hi,   We have CUCM 10.01 and Presense server with Jabber 12.1.  From normal desk phone there is no issue with outgoing calls. However when dialled from Jabber, the call disconnects after 4 rings if the other party didn't pick up the call. If they man...
Hello,   We have a UC560 environment that is not receiving any inbound calls. All attempts result in a busy signal. Outgoing calls are working fine.   When I run 'terminal monitor > debug isdn q931' I get the following.   004883: ISDN Se0/3/0:23 Q931...
CGreenJr by Level 1
  • 2011 Views
  • 2 replies
Hi, I'm looking to setup an IP Phone system in my home for the most part to learn the system. My setup would be 3 phones without passing data through to computers. Once comfortable managing the system I would then move it an office for my small busin...
Tac73 by Level 1
  • 336 Views
  • 1 replies
Hi all,I have a CUCM 9.1 and an IM&Presence 9.1Everything worked fine, but suddenly I can't anymore synchronize the users from CUCM to CUP.On the CUP, in the CUCM Publisher settings page, the Sync Status says "AXL failure". But just under that, in th...
testspa by Level 1
  • 10335 Views
  • 14 replies
Hi teami have the following output . Appreciate your helpful replies. Router#show platform softwarelicense License U D I : U C 560-F X O-K 9 :Maximum User Licenses : 56Used User Licenses : 0 Available User Licenses : 56Base License : 24C S L Base Lic...
