IP Telephony and Phones
Labels
Hi All, I’m doing a test on the auto attendant with hunt pilot routing. Below is the call flow I have now and it is working. User calling mainline (3000) -> there is a system call handler pickup and play announcement -> transfer to hunt pilot number(...
Unity connection 11.5 and Call Manager 11.5 My scenario is when a new message is left it will not turn the light on.  If I trigger the sync from the phone system in unity the light will turn on.  If I listen to the message the light will remain on.  ...
Hi,   I have a problem when configuring recording with Nexlog Recorder. I use BIB as Call Recording features on CUCM 11.5 instead of SPAN.I have prepared everything for this method and tried the below scenarios:Phone A (8861): Built in bridge enable,...
Is there a document out there somewhere listing the top ten causes for MWI synchronization problems out there somewhere? I had one user where MWI would not go on or off. Everyone else's MWI worked. I don't know what was different about this user BUT ...
Hello,   I was hoping to use a 7832 at a branch office, like my other non-cisco SIP phones and register to CME through "voice register pool", fast-track style. I uploaded the zipped firmware files to my flash and setup tftp-server settings for them. ...
I have a situation for the customer. . They need same DN number for login and logout condition condition but different privilage. when they login they should be able call external calls. in logout condition only internal and emergency numbers are all...
