Hi, Does anyone happen to know if there is a certain JAVA requirement for Attendant console to operate? Version 11.0.1. Thanks
Hello, What is the easiest/cheapest way to set up a lab for CUCM to simulate incoming and outgoing call? I have a Cisco VG202 I was wondering if this can be used to be the gateway I also found that 2811 routers are popular to do such lab? Is it po...
Is there an "alt-battery-feed feed2" command equivalent on a VG350 that can be used to boost the battery voltage ? Looks like alt-battery-feed feed2 command isn't supported on VG350.
Hello all! We have a hunt group with several members. One of the members is requesting a way to be alerted the call is coming in for the hunt group and not their personal extension. I think they would like it to keep the original CNAME and Caller I...
Hello everybody, i'm trying to configure a Cisco VG204 on Cisco ISR4321/K9 platform with CME version 12.1 Normally the configuration i should use on router CME is: voice-gateway system 1 network-locale FR type VG224 mac-address 001F.A30F.8331 voi...
Hi, I am using CUCM 11.x and trying to install "Conference Now" feature. I am not able to access my own conference meetings but I can join others meeting numbers. Any help would be appreciated. thank you, Muzaffar
Hi All I have a question that i hope someone here can help me shed some light on. We have a HCS deployment with CUCM clusters and IM&P nodes ,because this is a multi tenanted environment we can not use Service Discovery for the Jabber clients as each...
Hey Guys, I am planning an upgrade of my CUCM, am currently looking at the BE4000. The idea is to reuse all my handsets. Please say if these handsets will be able to use with the BE4000 USERS: 40-50 FUNCTIONS: ALL handsets: MODEL6921 Standard SCCP79...
anyone else had issues w/ Cisco 8800 series phone (8861/8851) where it's powered on, but there's no dial tone, or when you try to press any keys nothing happens. As if the phone is frozen, but if you wait a while, eventually it resumes normal behavio...
Hi Guys, My Customer have a Gateway 2921 with SIP Configured. In this equipment too having a FXO that not is identify the Caller ID. The Carrier told that identifier call is enable. Below the configuration FXO port. Are there another configuration ...
Hello, What's the best approach of upgrading an existing CUCM 9.x to 12.x? We have purchased a new BE 600M Server (M5) to run the new 12.x. My concern is, can I just backup the existing 9.x box using DRS and restore the flat-file on the new 12.x ...
We are trying to use MS AD LDS on Windows Server 2012 to replicated users from a Windows 2008 Domain Controller. I have the users replicated into the AD LDS server and all the common AD attributes are populated into the user objects. When I integrate...
We have multiple sites across a large metropolitan area and for emergency response notification, whenever 911 is dialed, based on CSS, the call is routed through a local POTs line attached to router at the location. The POTS lines address is that o...
How would I find out what the timeout status is for when a device goes from being registered to unplugged when it relates to the device status screen, see attached. We want to understand how long it takes from when a phone is showing registered to wh...
Hello everyone, We have a CUCM version 9.1.2.100000-28 and we need upload a firmware for Ip Phone model CP-8821-K9, but when I try connect with SFTP (online without problem) the plataform CUCM show the next message "The resource lock platform.api.upg...
Subject | Author | Posted |
03-21-2025 03:46 PM | ||
03-21-2025 01:42 PM | ||
03-20-2025 05:12 AM | ||
03-19-2025 06:53 AM | ||
03-18-2025 05:41 AM |
User | Count |
5 | |
2 | |
2 | |
1 | |
1 |
