SX20 provisioning failed GET Edge config:HTTP code=401
SX20 is in Singapore,cucm core is in Beijing.I have put rootCA cert in the SX20 already.Set NTP and DNS(local) already.Username and password was imported from LDAP.SX20 can not registered.
helloWhen trying to change the value of "Route Partition" in one phone, this error is displayed: The attempted action was a violation of security protocols and will not be allowed. This may be caused by having multiple concurrent windows open or ...
Hey! First of all, I'm completly new to Cisco IP Phones. We are a volunteer fire brigade and have about 70 Cisco IP Phones, most of them 7941, but also 7945, 7961 and 7965. Previously they were used in an other network, but now we want to put the...
Dear all. We want to prepeare for URI dialing because of 2 reason. One reason is a isco Bug if you mix 9971 and 8865 in a pickup group. Workaround would be to have an URI configured on the line. Second reason we want to prepare our Cluster for URI di...
Hi All, Can any one tell me does the after hour call block exemption- 'Login key' works with Cisco 7936.I am not able to find this soft key in the conference station. I even tried creating a soft-key template which includes the login softkey in it an...
I have a CUCM with release 6.1.2.1002-1. I also have a calls recorder (Asterisk). I did a trunk betweeen my CUCM 6.1.2.1002-1and Asterisk. I configured on CUCM the monitoring and recording feature.For that I configured a recording profile and I enabl...
I have an issue that when I am in SRST mode all calls both internal and external calls take about 10 seconds to ring. I have played with interdigit-timeouts but no luck. Anyone had this issue or anyone have any thoughts? It is a 2901 ISR router.
Hello, Can anyone tell us how to enable and then where to navigate to, to find the Remote Destination options on the Self Care Portal of CUCM for End User Options? Thanks, Tom
Hi community, I´m configuring speech connect in CUC 11.5, everything works well, the only problem is that I am not able to change the language in wich Unity answer to the user, I´ve seen in previous releases change the language was not supported. ...
Hello All, We just bought a Cisco 2921 and wish to use for CME an IP phones 8861 wish to know if something extra is needed before i can commence with the deployment. Attached below the sh version an sh license
Hi All I am looking into a global support partner for installation and support of our cucm and cucme services. It needs to be global, good presence in India, Europe, USA, Russia Can anyone recommend any? Many thanks Carl
Hello , i have CUCM 11.5 and Voice gateway ISR4321. in CUCM service Perameter , T302 set to 4000 but still i am having delay when dialing international calls. please advise . regards ,
dear im trying to create dial-peer voice pots but its shown an error: could not add peer as per attached pic The "ERROR: could not add peer" error message is displayed on the IOS voice gateway when an attempt is made to add a dial peer to an exi...
A little background. I have a 2811 at a client site setup with a single sip trunk. It worked at the client's old site. It no longer accepts inbound calls Nothing has been changed in terms of the config. I have a 2851 at home as a lab. I had it ...
example in CUCM, DN of 1000 - 1100 have a DID capabilities 1101 - 1200 just normal extension let say this 1 user is assigned DN 1210, but suddenly he want DID capabilities.how should I configured his DN to able DID without changing his DN to a new ...
Subject | Author | Posted |
01-25-2023 05:07 AM | ||
01-24-2023 11:30 AM | ||
01-19-2023 08:07 AM | ||
01-16-2023 05:26 PM | ||
01-16-2023 10:22 AM |
User | Count |
8 | |
7 | |
4 | |
4 | |
1 |
