IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5641 Views
  • 14 replies
Resolved! Translation Rule
Hello, I want to translate the DID number 35369750 to inbound extension 850  I applied this rule and voice translate profile under the port and tried voice translation  rule test and it translated ok but when I tried a call it failed and get success...
I am configuring Expressways for B2B calling. outgoing calls work fine. Incoming calls however are failing.  I see from expressway core call logs that the call in URi format is being transformed okay and is passed to CUCM. but in the logs i get 408 t...
pcromwell by Level 3
  • 3889 Views
  • 3 replies
Hi All,   I'm fairly new to the Cisco IP telephony world and am hitting a few roadblocks getting a basic working system setup.   One main wall I'm running into is getting my SIP trunk registering and working and I'm starting to pull my hair out a bit...
