Hi Everyone, I need help setting up the home Lab. Kindly suggest.. Hi Guys, Thanks in advance. I need help in setting up my Home lab & configuring my 2811 Router as PSTN . Can some one guide me through with the process of configuring my 2811 as P...
We are located in the Eastern US. I have phones all part of the same CSS. Some numbers can dial my 3 test long distance numbers 2 continental and one in Hawaii. Some phones can only call the continental and not Hawaii. When we dial the Hawaii number ...
I am not having much luck finding protocol for the SX20 for HTTP control. If you follow the API instructions, nothing will work. I found that the host must be added to the command for authorization string. Below is a command and response that works. ...
Hi all; I have a cisco ISR4331/K9 with E1, I need to get calls history from a week ago, using this file: https://www.cisco.com/en/US/docs/ios/12_3t/voice/command/reference/vrht_s04_ps5207_TSD_Products_Command_Reference_Chapter.html#wp1249092 ...
I was just looking at the CME roadmap and it doesn't show any point where a command was added so SIP could be used with IPv6 in CME. I would swear I saw someplace a firmware version for this. Do SIP phones not work with IPv6 in CME? I know SIP will w...
I have been playing aroung with a pretty simple and straight forward setup. A CUCM, a phone which is registered there and an ISR 4351 router, which has to play the role of CUCM and a SRST device. The SIP dial peers are configured on the router, but ...
Al agregar un dispositivo de sala Room Kit Plus muestra el siguiente error:Camera is not paired with codec and may need a software upgrade. Please check camera to codec connection.Como puedo solucionarlo?
Hello, We are a greenfield project and want to implement IP telephony system, Data network, CCTV camera system. We have been told that 1 cisco router ISR 4331 connected to 2 IP telephony server (1 redundant), FPR-2 110 Firewall and 2 Catalyst 296...
Have on campus various 7841, 7851, 79xx and then about a dozen or so 8831 conf phones. All phones register and work fine EXCEPT for the 8831s which continuously lose registration with CUCM. The solution is always the same - unplug ethernet cable an...
HI all, I am using 8841 ip phone and cucm version 10.5. 8841 model phone is not showing call history option. if I press application button, I am not seeing recents option to select. current phone firmware version is 11.7
Hi, We're having an anniversary issue with our Telco - flapping Controllers E1. The isdn switched-type are verified correct and there's really no progress on their investigation.The behaviour of the logs is it only takes 1 second of flap -down then u...
Hi Experts, i have trouble logging in with Jabber after CUCM IP change! Where does the Jabber pull the tftp info from ? seems its getting the old IP. Thanks
Hi! We have Cisco jabber on Windows and Mac and we use it for external calls, but we want to use it for internal calls. I need help to find out if it's possible to configure a Cisco Jabber to omit a part of a number and just call the last part that...
Hello, One of our subsidaries need intercom connection setup in such a way that it is locally controlled for specific times & then during other times it needs to be operated by an external company.CuCM is being used. Please suggest how to do this.
Hi, I configured Cisco extend and connect (https://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/211427-Configure-Jabber-Extend-and-Connect-and.html). At one customer it working without any p...
| Subject | Author | Posted |
| 12-13-2025 06:42 AM | ||
| 12-10-2025 11:24 AM | ||
| 12-10-2025 05:17 AM | ||
| 11-16-2025 10:18 PM | ||
| 10-15-2025 09:15 AM |
| User | Count |
| 4 | |
| 2 | |
| 2 | |
| 1 | |
| 1 |
