Hi All, i already integrate avaya system to Cucm with sip trunks. and already have good connection and communication, avaya have 611 1234 call to cucm 647 4321 and output in cucm phone 1234. cucm system have full number 60 647 4321 i want to ma...
Hi Guys, My Customer have the solution with CUCM 10.5.2 and we having the follow problem: the softkey template is not working to IP Phone model 7841. I am suspecting problem with firmware, because, I copy the same template 6945 that is working, but...
Good Day: Customer has a CME 11.6 system with SCCP 7931 and 7960 phones connected. The SCCP phones have the TrnsfVM softkey programmed and it worked well. Recently a handful of 8851 phones were provisioned on the system and installed. One signific...
Dear all, I have an issues with 7821 sip phones using cme 10.5 please help: please refer to attached. 1- internal calls some times and most of the times shows fast busy signals. 2- same issue with pots calls to pstn. 3- i tried to uprade from 10-1.1S...
Hi, Can someone pls help me in getting an alternate VOIP solution for" Cisco Call Manager Express (Cisco 2901 Integrated Services Router – 35 Phone license" as its in eol? Is be4000/6000 or C2901-CME-SRST/K9 appropriate alternate
Hello everyone, Very strange issue appear with my CUCM 9.1. From this monday all 9971/8865 phones unable to open Missed calls or Corporate dir. Missed calls just do nothing, Corporate Dir shows "Host not found" error. Of course, I checked Enterpr...
All, I've been working hard on some DTMF labs and some help in understanding some of the CUCM logs.. Here are some extracts and I would appreciate some comments on the below and also an understanding of the numbers/values etc that are set.. I normall...
Hi guys pls finf attached CUCM 10.5 modify bottom template , ip phone 7965 , only 2 add DN i need to add 6 DN line thanks all
Hello everybody, In a professional concern, and following a need for maintenance of the IP telephony platform, please help me to find the installation DVD of CUCM ver 8.6.2.2000-2. Thank you
All, Doing some labs at the moment for DTMF and seeing some unexpected/strange behaviours! I am using CUCM 11.5 with Cisco Jabber 11.9.3 and CIPC .The idea is to do some DTMF debugging between SIP and SCCP. Very simple intracluster calls from 1 end...
I am trying to upgrade to 8.x from 7.x, acualy I am installing a new server, and I was able to use Cobras to import most of the data from the 7.x server, except for the voicemail messages. I read that because I am using the Unrestricted version of U...
I have a cucm 9 connected to 2921 router MGCP Gate way we use FXO line we tried to replace the FXO by SIP trunk but when we try to make a call from out side to the call manager the telephone ring but when we pick up the phone we don not hear an...
I have a solution that use CME as SRST. I have 5 t1's into the gateway. DOes anyone have a sample config using this scenario. I cannot get it to work inside the customer as an internal call (BACD) or from the PSTN. I do have the BACD config guide. Ga...
We have a single cluster hosting multiple sites with EM enabled for all users. All external calls including emergency calls are routed out a SIP trunk hosted in a central datacenter. There are no local gateways at any site. As a result when EM user...
I have a cluster with 500 phones registered .. (CUCM 11.5) Is there any way to disable CORPORATE directory access to 300 phones ? thanks ,
Subject | Author | Posted |
04-15-2025 02:12 PM | ||
04-15-2025 10:57 AM | ||
04-15-2025 03:40 AM | ||
04-14-2025 01:50 PM | ||
04-14-2025 08:21 AM |
User | Count |
2 | |
2 | |
2 | |
1 | |
1 |
