Dear Community, as of other community discussions you can't change the font color of cisco IP Phones registered to a CUCM, but the discussion were few years ago. So is there now any possibility to at least choose between black and white? Or what ...
hi dear, i want to upgrade our cucm from 10.5, to 11.5, the scenario is we install new cucm 11.5 , so we will have 2 cucm different version running in different server and IP. and we will install it with PCD. the question is, how the new cucm...
hi friends: yesterday i installed 160 CUWL Standard (11.x) to the company CUCM , I used Prime License manger for installing the licenses, actually every thing is went fine, but what i have noticed that, the connection to the ldap sever is lost, eac...
Hi, We have a couple of sx20 (on diferent Regions). I call from one to another and it only TX/Rx at 384kbps video even if i choose a higher call rate. Its a SIP to SIP call on CUCM as Callcontrol. Thanks!
Hello, We have a problem with transferring calls outside. This is how topology looks like: PSTN - SIP - cisco router - SIP - CUCM 11.5 We need to transfer calls thats coming from PSTN, back through PSTN to outside number. This is what is configur...
Hi, I set up a call pickup group in CUCM 8.6 and associated 3 extensions (1001, 1002 and 1003), on the Cisco Ip Phone 3905. When I call from extension 1001 to 1002, while is ringins, I press the "center button" on extension 1003, but nothing happen...
Does the VG224 running MGCP support T.38? How can we tell if the VG224 supports H323 or SIP? We are trying to setup FoIP and have no clue as to what is needed.
*Apr 18 13:21:36.251: htsp_dsp_message: SEND_SIG_STATUS: state=0xC timestamp=30080 systime=-1606409220*Apr 18 13:21:36.251: htsp_process_event: [0/0/6, FXSLS_ONHOOK, E_DSP_SIG_1100]fxsls_onhook_offhook htsp_setup_ind*Apr 18 13:21:36.251: [0/0/6] get_...
I have a scenerio where I have CUCM and Cube via a sip trunk , A sip trunk between the Cube and an asterisk contact center and SIP trunk to an SIP provider for PSTN. I am able to make calls from the provider to the Call center and to the CUCM. But ou...
Hi, We have a Telephony platform linked to different locations across the world via sip trunks, we have a problem with 1 site using an old system (Nortel 1k), I think the sip trunk is configured as it should be, added the normalization script, and ...
Has anyone configured a Q-sys softphone third party SIP device? There isnt much on their site and I found an older DOC that steps us through it, but it will not register. Not much to configure in the APP itself. We have a user and a separate Device s...
Hi Team, I have a question about SIP Trunk Availability. Our customer had a 50 Line SIP Trunk Concurrent with agent Contact Center only about 20 person. On Peak hour, sometimes it's hard to incoming call come in and outgoing. I check the CDR data...
Hi All, I'm experiencing an unusual behavior of CUCM, when we extract a CDR from CUCM we see a Ring duration of 1000 sec or 16 mins also we saw 600 sec or 10 Mins, it means the IP phone was ringing for almost a minute. Now we investigating why this h...
I have a user who used to use a 7970 IP phone, he would use speaker phone at the same time as headset. He could set the headset as an additional microphone for speaker phone calls when there were a lot of people in his office. This made it easier f...
Hi there, I got a problem with IP phone 7937G register with CUCM 9.x. there are many models of IPT, includes 7940, 7942 and 7937, but only 7937 shows "Rejected" during registration. In addition, sometimes 7937 can registered with CUCM, the status...
| Subject | Author | Posted |
| 01-16-2026 03:24 AM | ||
| 12-31-2025 01:52 PM | ||
| 12-10-2025 11:24 AM | ||
| 11-16-2025 10:18 PM | ||
| 10-15-2025 09:15 AM |
