I bought a Cisco Desktop Charger Dock/Cradle for the Cisco 8821 mobile phone online. It's Part #CP-DSKCH-8821= The dock did not come with a power adapter to power the dock/charge the phone. Should it have? If not, where can I find one for it...
Hi All,I've tried to make factory reset on CP-7945G and have the following errors within TFTPD32: Firmware files were successfully sent to phone. error 2 in system call CreateFile The system cannot find the file specified. There is a need in follow...
I have a SIP Trunk out of CUCM to a VG. Doing a dialpeer debug I see it matching the correct dial-peer but I'm getting a "call cannot be completed as dialed". It's incoming/outgoing SIP to another VG, doing a csim start I see it routed correctly with...
I have a client where they have an Entrust CA and have it set up so that the only way they can create an Entrust cert for CUCM, is to 1.) from Entrust, generate a reference number for the certificate to be created, and 2.) assign that reference numbe...
Hi Guys Simple Question, when someone is setting the call forwarding settings in the sefl care portal - the options in the drop down list are "voicemail" and "add a new number..." is there any way so that the users can select a name, rather tha...
Hello, i have cisco call manager(CUCM) , 1 (publisher) and 2 subscribers (version 9.1.1) installed on MCS server , and i want to know how to move the current CUCM to VMWare.? Thanks
Hi to all,I'm installing a new CUCM with DNS information configured but I'm getting an error message about Reverse DNS lookup.I have a register in the dns for the name of the cucm and reverse dns lookup for the network that this server has configured...
Hi,I have a problem : after shutdown and no shutdown command the FXO hung, please do you have any solution ? Foreign Exchange Office 0/2/0 Slot is 0, Sub-unit is 2, Port is 0 Type of VoicePort is FXOOperation State is DORMANT Administrative State i...
I recently deployed CUCM 11. One issue we are having is frequently after calls the phone goes to the blue screen where it says "Phone is Registering". This frequently happens after a call and sometimes during a call. Then the users phone is down ...
Hello. I tray configure VoIP in my network. I don't found command telephony-service. I use router CISCO 881. On bottom is version mu soft. Please help me. Kind Regards.
Guys, I have multiple SIP trunks registered on my Gateway, and the calls are routed to cvp for IVR treatement, now i have to limit the channels for certain SIP trunks that are registered on my gateway, is there any way we can limit the channels on th...
Hi Freinds what is the best and recommended/easy/flexible method to register around 150 IP phones to CUCM 11.5 , Thanks
Hi all , I have a problem with extension mobility , I am using iphone cisco 7821 (SIP) and 7960 (SCCP). The iphones show me this error "Host not found" in the option "extension mobility". I am using router cisco 2921 with IOS c2900-universalk9-mz....
greentings We have two sip trunk that communicate with the PSTN through I have the Interns 87 ... come out by dial-peer 201 and the interns that start with 90 .. come out by dial-peer 202 both go out with 0XXXXXX Is there any way to configure it to ...
I was wondering two things one if you have an h323 gateway and a SIP trunk will the bind command on the interface interfere with each other. Also does the SIP trunk always up between the SP and the cube gateway (4321 ISR) It doesn't seem so. It looks...
Subject | Author | Posted |
04-28-2025 11:36 AM | ||
04-28-2025 05:35 AM | ||
04-26-2025 05:48 AM | ||
04-24-2025 02:49 PM | ||
04-15-2025 02:12 PM |
User | Count |
3 | |
2 | |
1 | |
1 | |
1 |
