Call Recording (SPAN less, via SIP Trunk) can't start if External Phone Number Mask is not NULL
How do I set a button label up for Floating Extensions so the label and not just the extension # shows on the sidecar list. I tried setting it up with a Normal button type but I ran into parameter errors and not sure how to fix them. There's no butto...
Hello there! We are upgrading our Call Manager to 6.1.3-3000 today, and during the upgrade the status went from 'Running' to 'The application has lost communication with the system. Check the status using CLI.' The install log still updates every fe...
hi there ... i have a sip trunk to an asterisk ... when user A call outside ( using sip trunk) it's work ..but when they cant transfer external call to each other . my trunk use g711ulaw..and i change my region configuration to use g711 ulaw ....
HEllo , As local Telco, going to upgrade voice technology from DiD to SIP..what the changes to be done in the existing configuration We are using 1 E1 PRI currently on Cisco2921 voice gateway
CUCM CUC IMP 11.5 I set up a Call Handler x1000 and it works fine. It has a couple caller input options and will default to HG if nothing chosen or 0 is pressed. I set up a Hunt Group w/Queue x2000 and it works fine (this also has vmail box) MOH & ...
Hi, Does anyone know if the CP-8841-3PCC-K9 (3rd Party Communication Controller) support VPN like the CP-8841-K9? Unable to find documentation on whether or not if it can if how to configure if it does. Thank you.
Hi all, i have a CME version Version 15.5(3)S3 and phone type 7861 configured. is there a way to get the call history from CME or phone. im not in the same place like the phone so go and see the call history directly from the phone is not an options....
I have two IP Phones 6921 when I connect them to the network they show phone not registered or network unavailable and when I go to the network settings the phone suddenly take an IP and become registered and can make calls then become not registered...
I have CUCM 11.5 and CUC 11.5 and 8841 and 8865 phones I believe that there is away just like playing with the greeting message. It should be a way when the someone calls a person that already talking to someone else it should say something like "the...
Hi, Is there a way to get access to the "full default linux shell" on the 8865 phone? I can get to the debug/debug shell via SSH on it but would like to get a similar access as on the 8900 series with "default" login. Thanks!
Good morning everyone, I encounter a problem during my PoC Project with Wazo (a fork of Xivo Asterisk-based IP PBX. I have three IP Phones : 2 SPA152G (works) and 1 CP-8851 + 8800 KEM (don't work). Our team has configured SEP file and the 8851 tu...
HI Guys Hoping someone can help me We have a customer with a UC540W who is having one way audio issues It does not happen on every call but on some calls throughout the day and also happens mid call They can hear me but I cannot hear them when callin...
Hi all I have run a scenario with 2811 cisco router (PVDM2-32 and 2mft2-t1/e1) 2811 is connected to ISP to receive 5 digit 79063 from outside and also 2811 is connected to panasonic TDA100D via a PRI/e1 link called number = 79063 calling number =...
I'm looking at the CDR report but can't understand all the details. where can i find supporting documents for the CDR report explanation? I also noticed that if call wasn't answered, it is not logged in CDR. how can i monitor when call jump to anoth...
Subject | Author | Posted |
06-19-2025 08:23 PM | ||
06-17-2025 07:43 AM | ||
06-17-2025 06:11 AM | ||
06-09-2025 09:11 AM | ||
06-05-2025 02:29 PM |
User | Count |
3 | |
2 | |
1 | |
1 | |
1 |
