IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6325 Views
  • 14 replies
Hello.  I'm running CUCM 10.5. I ship my CDR logs to an OfficeWatch server for department bill back, usage reports and 911 alerting. I received an alert that an extension dialed 911 and the call lasted 0 seconds. 30 seconds later, the user dialed 9,1...
Hello Everyone, The calls to the primary SBC provided by our SIP Trunk provider works with no issue. However, the same calls fail when they are sent to the secondary SBC. We are testing the failover and would like to send the call to the secondary SB...
I have run across two different phones that are exhibiting the similar symptoms.  Both 88XX phones have the CS 540 Plantronics headset with EHS cable APC-43.  Niether phones pick up the line correctly, in other words when you press the button to pick...
speedie49 by Level 1
  • 815 Views
  • 1 replies
