IP Telephony and Phones
Labels
Scope:Get a spa 962 to retrieve a config file from a server using tftp or http, and properly take up the settings.Users have reportedly done it, but the documentation from cisco has nothing whatsoever.Anyway,The xml config for the phone can be reache...
uhudson_z by Level 1
  • 1208 Views
  • 2 replies
Hello, I would appreciate some sort of suggestion for this inquiry----currently, we are using sort of a   'FLOOR MATS' for the handicap clients who needs to make a call to Switch board. They come on the top of a floor mat (using wheelchair)  and pres...
GWaldbin by Level 1
  • 7630 Views
  • 13 replies
Hi all, I am searching for a way to have the communication between VOIP-Gateway (ISR4000) and IP-Phone, between VOIP-Gateway and CUCM in the global-Routing-table, and the communication between VOIP-Gateway and SIP-provider in a VRF for security-reaso...
Resolved! Calling Party mask
Hi, Is there a way to assign  calling party transformation css to all phones ? Can we done without assigning to dp-pools?  How can I achieve the same functionality of  calling party transformation using a translation pattern  Thanks
elite2010 by Level 3
  • 865 Views
  • 2 replies
Ok, we are having an issue where some calls come into unity from some cell phone providers we are getting a DTMF added event for every dialed digit. We have a TAC case opened with not much of a resolution, other than we are better off now than before...
Hi    I'm trying to connect Cisco IP Communicator to UCCE 11.5 Environment any device not registered my laptop. I'm using IP communicator version 7 I think this version not supposed I have to upgrade 8 but still same issue.   I'm using windows 10 Pro...
asdeep1232 by Level 1
  • 3641 Views
  • 13 replies
Resolved! caller id
Hi I have 200 dids,and 250 phone I want to assign 50 non did numbers and assign a caller id 2430XXXX for outgoing (external) call .And another non did xxxx I want to assign caller id internaly(yyyy)and externaly 2430YYYY How can i do that? Thanks
  • 918 Views
  • 3 replies
