IP Telephony and Phones
ラベル
フォーラム投稿
Hi, I'm trying to upgrade cucm via cisco OS the gui.But im not quiet sure how to set freeftpd client and the cucm  source destination.I have my ISO files in my hard disk ( c:/cucm-files)But it keeps saying username or password is not valid, and somet...
monasir 投稿者 Level 1
  • 5826 閲覧回数
  • 8 返信
  • 0 いいね!
Does anyone know if the newer ISR 4K series of routers is backwards compatible with CUCM 8.6 using MGCP; and if so, is a COP file required for CUCM? After doing a little research it appears that the 4400 series does not support FXO/FXS lines and look...
CSCO12060329 投稿者 Level 1
  • 9115 閲覧回数
  • 13 返信
  • 0 いいね!
 Hello, I have a CME 7.1 with fourteen 7911 ip phones and four 4942 phones. When I place a call from any phone it gets a busy tone at random times, and I need to call several times to the same number until the call goes through.Does anyone has experi...
Julio_groeli 投稿者 Level 1
  • 11226 閲覧回数
  • 22 返信
  • 0 いいね!
Hi all, I'm having some issues while im trying to upgrade cucm .I have used different clients however with no succes.issues like :wrong username passwordcould not connect to remote location. Filezillasolarwindsfreeftpdcore ftp None of these have work...
monasir 投稿者 Level 1
  • 5816 閲覧回数
  • 3 返信
  • 0 いいね!
when an agent selects the "New Call" soft button to initiate a call the line chosen is whichever line was last used / selected. We would like to have this updated so that the "New Call" button also defaults to the primary extension in the same way th...
ttong2004 投稿者 Level 1
  • 326 閲覧回数
  • 1 返信
  • 0 いいね!
Hi!I have an issue with my cucm 10.5.I have a sip trunk that is connected to the telephone service provider, and when someone calls to another user of the same cucm, but dialing the long number (the number providade by the telephone service provider ...
mamaral 投稿者 Level 1
  • 381 閲覧回数
  • 1 返信
  • 0 いいね!
Dear all,I am having an issue with Cisco 3905 SIP phone on CUCME. The time displayed on all the phones is incorrect. More secifically the phones display the time as GMT and not the correct time zone.Here is my voice register global config:voice regis...
We are facing issue with Cisco IP Phone 7821 model.... CME 10.5 version we are using ..IP Phone is not registering ...when we go to the setting its ask us for credentials to check the settings ..where we are trying to check IP address parameters. one...
Vijay Patil 投稿者 Level 3
  • 418 閲覧回数
  • 1 返信
  • 0 いいね!
