NTP has associated with Date and time group.So someone please share the flow to get the time for SIP and SCCP phones. CUCM 10.x VER
hello like title, if i upgrade ip phone 9-4 firmware version, the phone gone to reject status so i restore firmware version 9-3-1 then, the phone registered These symptoms only occur on the 6921 model. 7911, 7962, 7975 is fine help me plz When...
Hi Everybody, Is there a way to bulk admin update the speeddial in UDP? Seems the bulk admin only for UDP only, not the speeddial button Thanks in advance Sam
Hello members, I have a new Cisco 8821 wireless phone which is not registering to my CUCM. I installed the latest device pack so the 8821 can be added and rebooted my CUCM clusters. I added the phone via Device>Phone>Add New on CUCM. On the 8821, I m...
Any help for POC of Cisco prime Provisioning will be appreciated. As per the CISCO PDI they don't support this and I am unable to find much information on Cisco.com. I need help for setting up this product and integrating with CUCM for real life use...
Good Day, I am facing issues to get a cisco 8841 phone work from external phone via VPN. It gives below message "Phone VPN connection failed: Could not connect to VPN. Please retry or contact your phone administrator". VPN Gateway, Profile and Group...
Hi, i have a Cisco VG248, i forget the enable password, and i want to recover it without forget the running configuration can you help me please?
All, I have been trying to get a Hot Dial phone set up for several weeks know and it has yet to function correctly. I have a old 7906 that sits on a wall out side a secure area that is supposed to ring into the security desk when it is picked up. We ...
How can reception transfer directly to a user's voicemail? System version: 10.5.2.11900-3
Is there a way on a VIC FXO to find out if there is an actual line plugged in to it?I know on a Linksys Gateway SPA400 the minute you plug the line in, the voltage indicator will change; which indicates that it's actually plugged into something. Is ...
Hi, Apologies if this is already in the pipeline or if someone has already thought about this however do you think there would be a market for a handset or Cisco USB device that would act as a docking station for a mobile phone. The handset/docking...
Hello, I urgently want to find out how I can register a Cisco 7945G IP Phone on a CUCM 6.0 Callmanager. I have tried, but did not see the option of 7945G. If I download the SCCP firmware and upload on the CUCM 6.0 callmanager server, will this wor...
Hi all, Can you advise i have configured SIP gateway for fax on router 2811 . Need to check whether the conf correct or not. Please find running conf. Thanks. Rafi
I have a branch router that has an ISDN PRI as its main line anda couple of FXS cards. The main location has our Call Manager. We have a FAX maching plugged into one of the FXS ports at the branch location. Our 4 digit extensions match the last 4 ...
Hi there, We have recently purchassed some new MX800, MX300 G2 video endpoints which have replaced our legacy Tanberg 880 units. The Tandberg devices were registered to the VCS-C appliance, where as the newer endpoints have been migrated onto the CU...
Subject | Author | Posted |
06-09-2025 09:11 AM | ||
06-05-2025 02:29 PM | ||
05-29-2025 01:49 AM | ||
05-23-2025 02:08 PM | ||
05-22-2025 11:54 PM |
User | Count |
5 | |
2 | |
2 | |
1 | |
1 |
