BE4000 COR
johntunks
Level 5
Level 5
I have a client that is looking to allow internal users to call Locally and Toll-Free.  Unfortunately, the CORs available do no allow that without opening full long distance calling.
  • Internal—Privileges to call numbers that are internal to the organization.
  • International—Privileges to call all numbers including international numbers.
  • Local—Privileges to call numbers within the same area code.
  • Local-Plus—Privileges to call numbers within the same area code with plus dialing.
  • National—Privileges to call numbers within the same nation code.
  • National-Plus—Privileges to call numbers within the same nation code with plus dialing.
Does anyone have a work around for this?  Pretty well looking for a Local + Toll-Free COR.
R0g22
You cannot have custom configurations on BE4k. The templates are pre-defined and the only ones that can be used.
Thanks for the quick reply.
Is there any roadmap to add more COR templates?  For instance Local and Toll Free is a common ask we run into.
I would call TAC to get a definite answer on that part.
