08-19-2019 09:36 AM - edited 08-19-2019 10:26 AM
Hello dears,
I was looking at the Be4k datasheet and it says it supports 200 device registrations. An ATA acts as a 2 devices so ises 2 device registrations.
Have these questions:
1. How do we connect the fax machines if there are 30 fax machines? Would that require 15 ATAs 191 model (it has two standard FXS ports)?
2. Would that same setup apply if there are 60 analog phones (requiring 30 ATAs)?
Thanks in advance!
Ton.
08-20-2019 04:35 PM
Anyone?
08-20-2019 04:46 PM
08-22-2019 12:57 AM
Thanks Anthony!
How about the VG series for bigger capacity for the analog phones, would that work same logic (connect to the BE4k/6k) as the ATA that only has 2 FXS ports?
Thanks in advance!
Ton.
08-22-2019 02:51 AM
Hello Ton,
If you need good capacity of Analog ports , you can use VG 310 and 320 which is the best option.
The Integration option would SCCP or SIP.
For SCCP you will have to add the gateway as Endpoint and all Analog ports will be registered on CUCM. There will be less configuration on Analog gateway in case of SCCP.
For SIP Integration , you will have to configure SIP trunk in CUCM towards Analog gateway and ports and dial-peer configuration will be done on Analog gateway.
Call Flow for SIP Integration== PSTN GW>>SIP/H323>> CUCM>>SIP Trunk>>Analog GW
Hari
08-27-2019 04:15 AM
08-27-2019 05:53 AM
Hi Raid,
You can configure up to 2 PRI/BRI/FXO/FXS with BE4K.
Refer Datasheet link given below.
