BE6000 Boot from SCU Partition on Flexfalsh to run server diagnostics.
Joey De Wiele
Hey,
I notice that the BE6000s have the "Onboard SCU Storage Support" BIOS option is set to "Disabled" making it impossible to boot from the Flexflash SCU partition to run diagnostics before deployment. If I set this to "Enabled", run my diagnostics, and then set it back to "Disabled" am I breaking some special "BE Rule"? Or is it recommended that I download the latest version of the SCU ISO and boot using the KVM virtual media?
Joey
Always good to state on the latest FW and no you not breaking any it is good to make sure all is 100%
Best Regards
Best Regards
Excellent and Thank You!!!!
