BE6K UCS Hard Disk Replacement
Hi All,
We have deployed BE6K. Among the four Hard Disks installed on the Cisco UCS C 220 server one of them found to be defective and we removed it. Do we need to do configuration to replace the new Hard Disk ? Please Help.
Best regards
kennedy
HI Kennedy.
UCS C 220 Hard Drives are hot pluggable and no configuration should not needed.
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/c/hw/C220/install/C220/replace.html#wp1220308
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
