03-19-2018 04:26 AM - edited 03-17-2019 12:26 PM
Hello All,
Can I use the BE6Ks as voice gateway only, the UC applications will be moved to another server?
Thanks in advance for your input.
Solved! Go to Solution.
03-19-2018 06:04 AM
If u are referring to BE6000S[2921V] , it can be used as a Voice Gateway which has a VWIC3-MFT-T1/E1 card with PVDM3.
regds,
aman
04-28-2018 10:31 PM
AS per Cisco @Jaime Valencia:
"From a technical perspective, there should be no problem, however, I've seen BU limitations on that in the past, for example, the UC500 series which you could use as an H323 GW, but the BU determined that would not be supported by Cisco. I'd suggest you reach out to your SE so he can confirm with the BE team if that would be supported, as it's sold as a UC appliance, and not a voice GW"
Thanks, Jaime.
03-19-2018 04:30 AM
03-19-2018 05:50 AM
It is combined router and UCS server, I am talking about BE6K small server (BE6KS)
03-19-2018 06:04 AM
regds,
aman
04-28-2018 10:31 PM
Thanks, Jaime.
