4150
ahmad_tamneh
Enthusiast
BE6KS as voice gateway
Hello All,
Can I use the BE6Ks as voice gateway only, the UC applications will be moved to another server?
Thanks in advance for your input.
2 ACCEPTED SOLUTIONS
If u are referring to BE6000S[2921V] , it can be used as a Voice Gateway  which has a VWIC3-MFT-T1/E1 card with PVDM3.
regds,
aman
AS per Cisco @Jaime Valencia:
"From a technical perspective, there should be no problem, however, I've seen BU limitations on that in the past, for example, the UC500 series which you could use as an H323 GW, but the BU determined that would not be supported by Cisco. I'd suggest you reach out to your SE so he can confirm with the BE team if that would be supported, as it's sold as a UC appliance, and not a voice GW"
Thanks, Jaime.
4 REPLIES 4
Mohammed al Baqari
VIP Advisor
B6k can't be a voice gateway. Its call control unit. Voice Gateway should
run on IOS/IOS-XE device
It is combined router and UCS server, I am talking about BE6K small server (BE6KS)
regds,
aman
Thanks, Jaime.
Create
Recognize Your Peers
Content for Community-Ad
