BE6KS Implementation Questions
Siva chinap
Level 5
Level 5
Guys,
I am going to implement BE6S(2921) Router with in built server,this bundle includes Voice cards & UC applications all in one...
Since it's my first deployment for BE6KS is there any new step by step doccument available?
11 Replies 11
Manish Gogna
Hi Siva,
Plz check the following post
https://supportforums.cisco.com/discussion/12450581/typo-be6000s-quick-start-guide
Thanks for ur info...which really helpful for me
[+5] Monish
Good to know it Siva, its a bit strange that the quick start guide or deployment guide for BE6KS does not come up when we search on google.
Manish
Hi Manish,
Can you brief me the steps which you have taken while configuring BE6KS. I have couple of BE6KS Implementations waiting around, appreciate your help in getting the steps involved to configure BE6KS.
All i came to know is that Router has a sample configuration and I am not sure how do we to set it up, so that UCS E160D with CUCM as an application will communicate through 2921.
Thanks in advance,
Solomon.
Hi Solomon
This should give you a start
http://www.cisco.com/c/en/us/support/unified-communications/business-edition-6000/products-installation-guides-list.html
Thank you Wilson for the link. I do know implementing BE6K Enterprise edition be it MD or HD. All I need to know how we do it for the newly emerged solution BE6KS. In Cisco, apart from Quick Start Guide, I did not find any other document related to this Solution.
Solomon.
Yes, the Be6ks is a little different. I do not use the preconfigured version because we have a standard base config that we use for all of our installs. have gone through about 3 BE6Ks installs and have trouble with each one, if we could get a guide with the differences at least that would be great. Thanks!
you can refer the link
http://www.cisco.com/c/en/us/products/servers-unified-computing/ucs-e-series-servers/models-comparison.html
http://www.cisco.com/c/dam/en/us/products/collateral/servers-unified-computing/ucs-e-series-servers/qa_c67-625001.pdf
regds,
aman
Thank you Aman, but I meant a configuration guide. There are config guides for a regular be6k everywhere but for the s there is nothing on Google.   There are a few extra steps that need to be taken on the s for it to work correctly in the network and for the 2921 to communicate with the server correctly.
Hi Randle,
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/e/2-0/gs/guide/b_2_0_Getting_Started_Guide/b_2_0_Getting_Started_Guide_chapter_0101.html
regds,
aman
Hello Shiva,
Have you Installed BE6K S at your site. If yes can you please get me the steps around it, apart from Quick Start Guide. I have one Implementation scheduled next month. ANy Help much Appreciated.
Solomon
