07-18-2015 11:35 PM - edited 03-17-2019 03:41 AM
Guys,
I am going to implement BE6S(2921) Router with in built server,this bundle includes Voice cards & UC applications all in one...
Since it's my first deployment for BE6KS is there any new step by step doccument available?
07-19-2015 05:51 AM
Hi Siva,
Plz check the following post
https://supportforums.cisco.com/discussion/12450581/typo-be6000s-quick-start-guide
07-20-2015 04:09 AM
Thanks for ur info...which really helpful for me
[+5] Monish
07-20-2015 04:17 AM
Good to know it Siva, its a bit strange that the quick start guide or deployment guide for BE6KS does not come up when we search on google.
Manish
07-30-2015 08:57 AM
Hi Manish,
Can you brief me the steps which you have taken while configuring BE6KS. I have couple of BE6KS Implementations waiting around, appreciate your help in getting the steps involved to configure BE6KS.
All i came to know is that Router has a sample configuration and I am not sure how do we to set it up, so that UCS E160D with CUCM as an application will communicate through 2921.
Thanks in advance,
Solomon.
07-30-2015 04:54 PM
Hi Solomon
This should give you a start
http://www.cisco.com/c/en/us/support/unified-communications/business-edition-6000/products-installation-guides-list.html
07-31-2015 12:08 AM
Thank you Wilson for the link. I do know implementing BE6K Enterprise edition be it MD or HD. All I need to know how we do it for the newly emerged solution BE6KS. In Cisco, apart from Quick Start Guide, I did not find any other document related to this Solution.
Solomon.
01-08-2016 06:18 PM
Yes, the Be6ks is a little different. I do not use the preconfigured version because we have a standard base config that we use for all of our installs. have gone through about 3 BE6Ks installs and have trouble with each one, if we could get a guide with the differences at least that would be great. Thanks!
01-08-2016 06:29 PM
you can refer the link
http://www.cisco.com/c/en/us/products/servers-unified-computing/ucs-e-series-servers/models-comparison.html
http://www.cisco.com/c/dam/en/us/products/collateral/servers-unified-computing/ucs-e-series-servers/qa_c67-625001.pdf
regds,
aman
01-08-2016 08:19 PM
Thank you Aman, but I meant a configuration guide. There are config guides for a regular be6k everywhere but for the s there is nothing on Google. There are a few extra steps that need to be taken on the s for it to work correctly in the network and for the 2921 to communicate with the server correctly.
01-08-2016 11:55 PM
Hi Randle,
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/e/2-0/gs/guide/b_2_0_Getting_Started_Guide/b_2_0_Getting_Started_Guide_chapter_0101.html
regds,
aman
08-28-2015 07:57 AM
Hello Shiva,
Have you Installed BE6K S at your site. If yes can you please get me the steps around it, apart from Quick Start Guide. I have one Implementation scheduled next month. ANy Help much Appreciated.
Solomon
