11-06-2017 10:45 PM - edited 03-17-2019 11:33 AM
Hello Everyone,
In next month, there is Audit schedule so i would like to know the best CUCM configuration means as per CISCO recommendation config guide, if anyone have it already so please share me OR give me the correct path. Or, share me if you have a best link to download the same.
Viru
Solved! Go to Solution.
11-07-2017 05:52 AM
Typically audits focus on Security, so I suggest you start with review of the CUCM Security Guide for your version of CUCM. Here is link for version 11.5:
11-06-2017 10:53 PM
11-07-2017 05:52 AM
