03-02-2015 07:44 PM - edited 03-17-2019 02:11 AM
HI,
Could you please help me to analysis which is the best software for CUCM CDR report .
Debabrata Majhi
03-02-2015 08:57 PM
Hi Majhi,
you can have a look into Variphy.
http://www.variphy.com/products/enterprises/cisco-call-history-reporting
regds,
aman
03-03-2015 08:07 PM
We use software called PhoneControl Weblink. Very detailed and customisable.
Cheers
Ben
03-03-2015 09:02 PM
Cisco Prime Collaboration Assurance is another, check below data sheet link
http://www.cisco.com/c/en/us/products/collateral/cloud-systems-management/prime-collaboration/datasheet-c78-733113.html
HTH,
Mohammed Noor
03-07-2015 02:20 AM
03-07-2015 02:18 AM
We got the downlink link after reguster.We will let you know the status ASAP
04-06-2015 09:26 PM
You may also check IPERA Communication Suite. Provides 400+ drill-down reports for various purposes including Call Accounting, Expense Management, Call Analysis, Resource Utilization Analysis (Trunk/Gateway), etc.
For more information visit iperamea.com
MD
05-03-2015 05:24 AM
Cisco Compatible Billing and Call Management Software
http://www.connectps.com/cisco-xml-services-for-ip-phone.htm
04-16-2019 02:10 PM
08-09-2019 12:18 PM
Call Record Analyzer is a newer cloud based CDR/CMR reporting/troubleshooting tool that has great visual scheduled reporting, Call Transfer tracer that visualizes crazy call transfers call leg by leg, and location based visualizations for troubleshooting QOS related issues from phone in a specific CAC region vs. the Cube GW vs. the UCM cluster.
Call Record Analyzer (CRA) Website
03-13-2023 09:27 AM
Another option would be VoIP Detective. We offer a free version as well as a PRO version. It includes CDR reporting, UCCX wallboard, CUBE analytics and more.
