10-11-2010 11:17 AM - edited 03-16-2019 01:16 AM
Im using 8.x and I need to get a report to see which ph
ones are currently registered.
I see RTMT but need to get a csv file.
Which is the best tool?
10-11-2010 12:33 PM
Use CUOM (Cisco Unified Operations Manager) to serve your purpose, it can help you as exactly what are you looking for!
Hope this helps!
Mijanur Rahman
10-11-2010 02:34 PM
email me if you are interested in a cheaper tool
if you are looking for this;
Devicename,Description,IPAddress,Status,CUCM
SEPAABBCCDDEE,Auto 1234,1.1.1.101,Registered,1.1.1.10
(or more if required)
