06-21-2018 12:10 AM - edited 03-17-2019 01:03 PM
What is the best way to kick start, or restart the SIP-UA registration process on a cube ... other than restarting the gateway or deleting the registrar info and re-adding it.
Note: This SIP Provider is not on a dedicated interface so shut/no shut is not applicable here.
Something like "Restart SIP-UA"?
06-21-2018 12:36 AM
06-21-2018 12:42 AM
Try this command and see if it helps
call service stop
It will shut down VoIP call service [SIP] on a gateway, use this in voice service SIP.
08-23-2022 01:40 PM
Hi, i want to add an additional help
rt#conf t
rt(config)#voice service voip
rt(config-voi-serv)#sip
rt(config-serv-sip)#call service stop
rt(config-serv-sip)#no call service stop
rt(config-serv-sip)#end
now check that the calls enter the gw.. sh sip-ua calls brief or run a debug ccsip message
bye
