11-17-2008 07:49 AM - edited 03-15-2019 02:35 PM
What is the billing system for CCM7.
Solved! Go to Solution.
11-20-2008 06:47 AM
ISI Infortel solution is the one I use the most it is solid and they have been a long time partner with Cisco.
11-20-2008 06:59 AM
Hey Slava,
Hope all is well!
The Cisco Partner program has a number of tested solutions for Billing/Accounting (CDR) products. Here is the link;
http://forums.cisco.com/eforum/servlet/IPCApps?page=Call_Acct_Billing
Hope this helps!
Rob
11-17-2008 10:29 AM
if you mean if we include a billing system with CCM we don't. we only provide CAR with the limited functionality it has.
you're free to look into the partner locator for billing systems compatible with your version since you do not mention what you have
java
if this helps, please rate
11-20-2008 06:40 AM
Hi. Wi have Cisco Call Manager 7.
11-20-2008 06:47 AM
11-20-2008 06:59 AM
Hey Slava,
Hope all is well!
Hope this helps!
Rob
11-20-2008 07:08 AM
thanks for you help.
11-20-2008 07:10 AM
Slava,
You are always welcome my friend!
Rob
