05-10-2012 03:17 AM - edited 03-16-2019 11:05 AM
I have one user who is unable to pick up calls using the BLF. When they attempt to pick up a call they get a "temp fail" message. I have logged the user into a different handset and the issue follows the UDP. I have deleted and recreated the extension and UDP but the issue still occurs.
We are running CUCM 7.1(3)
any help much appreciated.
cheers
Kev
Solved! Go to Solution.
05-10-2012 05:55 AM
Hi Kev,
This "Temp fail" error has been seen when the wrong Pickup Group
has been assigned in error. Can you verify that portion of the config
Cheers!
Rob
"Everything is broken" - Bob Dylan
05-10-2012 05:55 AM
Hi Kev,
Cheers!
Rob
05-10-2012 07:13 AM
Cheers Rob, it was a pickup group issue. They were in the same group but it wasnt working at all. Created a new group and all working.
thanks again.
Kev
12-15-2021 03:42 AM
Yes, that's right. Adding new Pickup Group and assign DNs to it remediate the issue! Thanks kevbo!
