BLF Issue with CME
marc.obrecht
Hi team,
I have an issue with a IP Phone 7975 with a 7916-24 extension module.
I configured the phone with 12 BLF, but only the first 7 are working.
This is the configuration :
ephone  1
device-security-mode none
mac-address XXXX.XXXX.XXXX
presence call-list
blf-speed-dial 1 250 label "USER1"
blf-speed-dial 2 425 label "USER2"
blf-speed-dial 3 445 label "USER3"
blf-speed-dial 4 156 label "USER4"
blf-speed-dial 5 205 label "USER5"
blf-speed-dial 6 784 label "USER6"
blf-speed-dial 7 123 label "USER7"
blf-speed-dial 8 478 label "USER8"
blf-speed-dial 9 789 label "USER9"
blf-speed-dial 10 459 label "USER10"
blf-speed-dial 11 789 label "USER11"
blf-speed-dial 12 458 label "USER12"
type 7975 addon 1 7916-24
button  1:15 2:12
I can change the order of the BLF as I want but it's always the same result, 7 first BLF work and 5 last don't...
I think it's not an extention module issue because the first BLF on the module work fine.
When I look at the debug ccsip message, I saw that the phone send a subscription for the 7 first BLF of the list but nothing is sent for the 5 other BLF.
In addition, on the sh presence subscribe the last 5 BLF are not present.
On the phone, the BLF button are shown as speed dials...
Best regards,
Marc
Try reloading router. That is also a good occasion to update IOSm in order to gain new features and better stability.
5 Replies 5
Rob Huffman
Hi Marc,
Just curious about two things;
1- what happens if you set up the 7916 as a 12 button rather than 24?
2- have you looked at the button layout?
8.5
Customized Button Layout
Allows you to customize the display order of various button types on a phone using the button layout feature. The button layout feature allows you to customize the display of the following button types:
Line buttons
Speed Dial buttons
BLF Speed Dial buttons
Feature Buttons
ServiceURL buttons
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeroad.html
Configuring Button Layout on SCCP Phones
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmelabel.html#wpxref48727
Cheers!
Rob
Hi Rob,
1. Nothing is appening, it's always the same thing, the two button lines and the 7 first BLF are working fine but the 3 last BLF don't.
2. Unfortunatly I am in CME 7.1, so I can't enter the layout commands...
The fact is this configuration worked fine until yesterday and a reboot of the phone by a user.
I have this configuration on another phone but I do not have this problem...
Best regards,
Marc
Hi Marc,
Did you try deleting the ephone and creating it again?
Best regards,
Alex
Hi all, yes I did the delete and recreate opereration but, nothing new...
I think I am good for an IOS upgrade.
Tks all,
Bye
Marc
