BLF/Monitoring
caflippo76_2
Hi All,
I have 5 phones sharing one extension.
I would like to see the status of each of those devices.
I thought the BLF would do the trick...But, was not able to get it to work.
How can I monitor devices and not extensions?
CUCM 6.1    7961 devices
Jaime Valencia
You can't.
Presence
Tip For presence-supported SIP phones, you  can configure directory numbers or SIP URIs as BLF/SpeedDial buttons.  For presence-supported SCCP phones, you can only configure directory  numbers as BLF/SpeedDial buttons.
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucmbe/admin/6_1_1/ccmfeat/fsprsnc.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
