2727
BLF SD... red light is always on!!!
Dear Team,
The BLF-SD light is always on one IP phone only. All the others are woking fine.
Tried rebooting/reseting/reconfiguring the IP Phone, still no avail.
Also the symbol on the IP Phone is a little different.
Usually the symbol is a Phone on top of the Speed Dial symbol.
Here its like - SpeedDial -> Phone -> and then there is "x" inside the phone.
Have any of you faced this issue before.
Shabeeb Mohammed
1 ACCEPTED SOLUTION
Re: BLF SD... red light is always on!!!
Do Not Disturb is turned on for that DN.
3 REPLIES 3
Dear Jonathan,
Thanks a ton.
Regars
Shabeeb
Highlighted
This is awesome. Thanks a lot
Content for Community-Ad
August's Community Spotlight Awards
